| Using Fedora General support for current versions. Ask questions about Fedora and it's software that do not belong in any other forum. |
26th June 2007, 02:45 AM
Unable to play h.264 video.
I have totem-xine mplayer and vlc installed. None of them seem able to play this video type, regardless of the container. I got the same problem with .mov .avi and .mkv containers.
I have x264.x86_64 installed.
Totem-xine mplayer and vlc are all installed from the livna repository. Searching my repos and this forum came up with nothing helpful.
I really would like to get this working in mplayer, since that is my primary video plugin for firefox.
26th June 2007, 03:08 AM
Retired Community Manager
Hello:
I just tested an .avi and .mov file with vlc and mplayer and it plays fine here ?
Don't have any of the others handy to test at the moment, sorry.
Here is what I have installed, hopefully it helps, as I honestly don't know which is what
PHP Code:
# yum list | grep vlc
vlc.x86_64 0.8.6c-1.lvn7 installed
PHP Code:
# yum list | grep -F mplayer
mplayer.x86_64 1.0-0.76.20070612svn.l installed
mplayer-fonts.noarch 1.1-4.lvn6 installed
mplayer-gui.x86_64 1.0-0.76.20070612svn.l installed
mplayer-skins.noarch 1.8-1 installed
mplayerplug-in.x86_64 3.40-1.lvn7 installed
mplayerplug-in.i386 3.40-1.lvn7 installed
PHP Code:
# yum list | grep -F gstreamer
gstreamer.x86_64 0.10.12-1.fc7 installed
gstreamer.i386 0.10.12-1.fc7 installed
gstreamer-devel.x86_64 0.10.12-1.fc7 installed
gstreamer-devel.i386 0.10.12-1.fc7 installed
gstreamer-ffmpeg.x86_64 0.10.2-2.lvn7 installed
gstreamer-plugins-bad.x86_64 0.10.4-2.lvn7.1 installed
gstreamer-plugins-bad-devel.x86_64 0.10.4-2.lvn7.1 installed
gstreamer-plugins-base.x86_64 0.10.12-2.fc7 installed
gstreamer-plugins-base.i386 0.10.12-2.fc7 installed
gstreamer-plugins-base-devel.i386 0.10.12-2.fc7 installed
gstreamer-plugins-base-devel.x86_64 0.10.12-2.fc7 installed
gstreamer-plugins-farsight.x86_64 0.12.1-1.fc7 installed
gstreamer-plugins-good.x86_64 0.10.5-6.fc7 installed
gstreamer-plugins-good-devel.i386 0.10.5-6.fc7 installed
gstreamer-plugins-good-devel.x86_64 0.10.5-6.fc7 installed
gstreamer-plugins-pulse.x86_64 0.9.4-4.fc7 installed
gstreamer-plugins-ugly.x86_64 0.10.5-2.lvn7 installed
gstreamer-plugins-ugly-devel.x86_64 0.10.5-2.lvn7 installed
gstreamer-python.x86_64 0.10.7-2.fc7 installed
gstreamer-tools.x86_64 0.10.12-1.fc7 installed
PHP Code:
# yum list | grep -F xine
totem-xine.x86_64 2.18.0-1.lvn7 installed
totem-xine-plparser.x86_64 2.18.0-1.lvn7 installed
xine-lib.x86_64 1.1.7-1.fc7 installed
xine-lib.i386 1.1.7-1.fc7 installed
xine-lib-extras.x86_64 1.1.7-1.fc7 installed
xine-lib-extras-nonfree.x86_64 1.1.7-1.lvn7 installed
xinetd.x86_64 2:2.3.14-12.fc7 installed
PHP Code:
2.6.21-1.3228.fc7 #1 SMP Tue Jun 12 14:56:37 EDT 2007 x86_64 x86_64 x86_64 GNU/Linux
Seve
Registered Linux User: #384977
See the Links below for more Help and those much wanted extras ... :)
26th June 2007, 03:29 AM
Hmm, my vlc xine and mplayer installs look about the same as yours. I have a few extra .i386 things installed. I don't have the gstreamer-devel stuff installed, but otherwise the same there also. Kernel is the same.
Did you install the codecs from the Stanton Finley guide?
26th June 2007, 03:38 AM
Hello:
Yes, I'm sorry I forgot to add that.
I used the package from ftp://ftp1.mplayerhq.hu/MPlayer/rele...061022.tar.bz2
Now, you're wondering where I put them ?? Let me check
/usr/local/lib/codecs
/usr/local/lib64/codecs
/usr/lib/codecs
/usr/lib64/codecs
/usr/lib/win32
/usr/lib64/win32
and I think that's it.
Seve
26th June 2007, 04:06 AM
Hmm, that does not appear to have been effective. Would you take a look at this video stream and let me know if you can see it?
26th June 2007, 04:13 AM
Hello:
Nope I cannot play that ... it sends firefox wild .. using 100% cpu
Seve
26th June 2007, 04:16 AM
Oh well, looks like a problem with the "quicktime" video streams from here then.
26th June 2007, 04:42 AM
Hello:
It did manage to play here, although my connection to their server is pretty lousy.
See the attached.
Seve
26th June 2007, 07:01 AM
If the server is that bad, maybe I won't worry about the h264 video. Out of curiosity, do you have port 32788 open? That is where I always get stuck.
26th June 2007, 05:17 PM
Hello:
I fired it up again today and the stream was a little bit better, but not much.
My guess is that the lack of a sustainable stream from the server is the real issue.
Yes, I have seen the same port thing, however, I did not adjust anything with my firewall(s)
Seve
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Current GMT-time: 09:18 (Sunday, 19-05-2013)
