Old 10th August 2007, 02:32 PM
fedora111 Offline
Question xine cannot work with xgl???
Hello everyone! Today I just find an odd thing: when I enable the Desktop Effects I cannot get xine to work, so as totem-xine. I open xine in a terminal and find the following report:
[fedora111@localhost ~]$ xine
This is xine (X11 gui) - a free video player v0.99.5.
(c) 2000-2007 The xine Team.
AFD changed from -2 to -1
X Error of failed request: BadAlloc (insufficient resources for operation)
Major opcode of failed request: 140 (XVideo)
Minor opcode of failed request: 19 ()
Serial number of failed request: 2285
Current serial number in output stream: 2286
Would anyone tell me what to do to solve the problem? Can it be fixed? Thx all the way!
Old 10th August 2007, 03:35 PM
FriedChips's Avatar
FriedChips Offline
hmmm. My xine works and I run gdm + xgl + beryl so I don't think it is xine not compatible.. What are your system specs? Graphics, cpu, ram
The answer to all of lifes questions are buried somewhere in the Google search engine.
[Stephen@localhost ~]$ whatis this?
this?: nothing appropriate
Old 9th October 2007, 11:28 AM
dholwerda Offline
its a problem with desktop-effects - run from a terminal gstreamer-properties and change the video from auto to xv
Old 8th October 2008, 04:09 AM
saywot Offline
after doing this I get a message not dissimilar to the OP
]$ xine
Serial number of failed request: 2294
Current serial number in output stream: 2295
Xine flashes open, then just as quickly climbs back in it's box
work, xgl, xine
Sound won't work right, xine won't install. Mechphisto Using Fedora 3 27th May 2008 08:50 PM
Xine doesn't work anymore nwinkler Using Fedora 0 16th July 2007 02:06 PM
FC5: rmvb movies in xine don't work. 1xused Using Fedora 12 6th April 2007 07:23 AM
xine installation??? doesn't work... bigred Using Fedora 7 20th January 2005 02:17 AM
Current GMT-time: 18:43 (Wednesday, 22-05-2013)
