Old 27th August 2007, 04:32 PM
ssb Offline
logger and tail -0f
I am trying to test festival and an example using /var/log/messages but i can't do running ...
As root, i run the script
#!/bin/bash
tail -0f /var/log/messages | sed "s/^[^:]*:[^:]*:[^:]*: //"|while read LINE
do
echo $LINE | festival --tts
sleep 0.75
done
it seems ok, but, i dont know why, no events are reading by "read LINE',
because, if i use set -x , traces allways shows + read LINE .... waiting ..
and if i write something using logger command, no work too ... but texts
are writting into the file ..
but the scripts works with other files ... um ..
what about /var/log/message ?
what am i doing wrong ?
thank you
logger, tail
activity and key logger x6vhcb5 Using Fedora 2 8th April 2009 05:25 PM
Keystroke Logger wberry2 Using Fedora 11 28th March 2007 09:41 PM
I lost the logger in AMD 64 gomex Using Fedora 1 29th August 2006 09:24 AM
System logger Sancho- Hardware & Laptops 2 4th December 2005 01:06 PM
keystroke logger luibh Using Fedora 2 3rd April 2005 08:18 PM
Current GMT-time: 11:00 (Thursday, 23-05-2013)
